Old 02-20-2011, 05:47 PM   #1
honeywell thermostat
My old digital thermostat has brown wire to C, Yellow to Y, Green to G, Blue to B, Red to R, White to W/W1 and my new Honeywell thermostat has O/B and W on same slot. what do i do with the blue and white wires? put them on same slot?
martin86 is offline   Reply With Quote
Old 02-20-2011, 06:45 PM   #2
Professional
sounds like you dont have the right stat if no w2 or aux terminal on new one. Do you have a heatpump with back up heat (electric strip or gas)
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-20-2011, 06:49 PM   #3
electric and sorry it has W2 do i use that?
Old 02-20-2011, 06:56 PM   #4
Professional
old--color--new
R--RED--R
C--BROWN--C
Y--YELLOW--Y
G--GREEN--G
B--BLUE--O/B
W/W1--WHITE--W2 AND JUMPER TO E IF APPLICABLE TERMINAL
IT IS WHAT IT IS
Old 02-21-2011, 05:55 AM   #5
An old Tradesmen
Your Honeywell thermostat uses W/OB as your B on the old stat, and W2 as the W on your old stat.
Sounds like you have a Rheem/Rudd/Weatherking heat pump. If so, you also have to tell the stat to energize W/OB in heat mode.
Honeywell thermostat wiring wcb22 HVAC 5 01-10-2011 06:54 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
