Honeywell Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 04-05-2013, 07:05 AM   #1
honeywell thermostat
Honeywell stat wired to xl60 trane gas furnace i know im missing something simple furnace has stevco fan relay fan relay not energizing therfore burners light and kick out fan limit ive got no high voltage going to fan limit im thinking on honeywell stat i need to jumper w to w1 so stat sends voltage to fan relay just got a brain fxrt
dvdacmn is offline   Reply With Quote
Old 04-05-2013, 07:48 AM   #2
Rewards Points: 582
show picture of stat wiring and wiring at control board on furnace
Old 04-05-2013, 08:02 AM   #3
wiring
89 model trane no pics or board xformer red stat green stat & stevco fan relay common to fan relay &gas valve & condenser w from stat to w & w threw safeties to limit switch to gas valve mv i need to energize stevco fan relay to get 115 to fan limit thinking i need to jumper w to w1 on the Honeywell stat so it energizes fan relay iv got 115 going to fan relay no low voltage think it was hooked up to b terminal on old white rogers stat
Honeywell / Honeywell thermostat replacement question. FatBear HVAC 15 05-05-2014 02:15 AM
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 07:22 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
