Old 07-18-2012, 02:34 PM   #1
Honeywell Thermostat
I have a Honeywell TH8320up1011 Thermostat that I had in my other home...Had both gas furnace and air conditioning unit. Now I have baseboard heat and electric air conditioning. Tried several ways to wire but thermostate for the air conditioner but not successful. Have 4 wires...Only the red, green & yellow(blue) were used on existing thermostate. There is a white wire available.
jrbizjak11 is offline   Reply With Quote
Old 07-18-2012, 02:44 PM   #2
biggles's Avatar
hot water baseboard? if you have a stand alonf with no zone valves then it is just adding an isolating relay down on the boiler.then wire the R and W for the heat the AC side Rc/Rh,G,Y s normal connections down into the air handler .the reson for the isolating relay is the boiler has it's own transformer so your just closing the relay to call the boiler in
Old 07-18-2012, 03:33 PM   #3
If you're trying to wire for A/C ONLY, then you need only Red, Green and Yellow terminals on the t'stat. You wouldn't use the White terminal at all (that's the Heat load). They should be tied to your current thermostat's R, G and Y terminals. If not, then take some pictures and post them back here.
scottmcd9999 is offline   Reply With Quote
Old 07-19-2012, 04:20 PM   #4
No, electric baseboard. Each room has seperate switch/thermo.
Old 07-19-2012, 04:23 PM   #5
Honeywell tells me 4 wires are needed to work. won't give wire diagram over phone.
Honeywell RTH111 Thermostat justplumducky HVAC 8 06-11-2011 12:14 PM
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 07:22 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
