Honeywell Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 11:54 PM   #1
honeywell thermostat
no power or display
jljenkens is offline   Reply With Quote
Old 07-11-2012, 03:32 AM   #2
HVAC Contractor
Rewards Points: 336
Change batteries.
If no batteries, check for power at thermostat. Jump the R and G wires - does the indoor fan come on? If it does, then chances are you have a bad tstat. If it does not, then you have control voltage issues, and you'll have to get to the control section of the air handler to continue troubleshooting. Note that when you get to that section, you'll be dealing wtih 110 or 220 volts, so BE CAREFUL. Look for a circuit board, see if you find an automotive-type fuse on that board. If it's blown, replace it. If it blows when you replace it, you should probably call a contractor to trace down the short.
scottmcd9999 is offline   Reply With Quote
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 06:22 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
