Honeywell Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 02:03 AM   #1
Trying to changge out old white rodgers for new digital honywell and cant find out what W3 is for? My old thermostat had wires and connections for:
x=blue
w3=pink
w2=white
l=grey
r=red
g=green
o=orange
y=yellow
e=brown
b=nothing
A1=cant see in pic
Im going to look into air handler and outside unit and follow up with brand and size. Im not familiar with this unit since its my rental and havnt seen the inside since it was installed approx 8 yrs ago. my new therm doesnt have a w3 on it? will post a pic when I can figure out how to not exceed limit on upload pics
cariboulou is offline   Reply With Quote
Old 02-18-2012, 05:31 AM   #2
An old Tradesmen
Rewards Points: 6,080
Second stage of aux heat.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (02-18-2012)
Old 02-18-2012, 05:34 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
post pictures to a free online photo sharing site such as photobucket and then post the link to the picture here or use the insert image button just above the reply box.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-18-2012, 08:08 PM   #4
Ok, gonna try again with lower res pics tonight. Its an intertherm air handler and I forgot what brand condenser? But current wiring connections are like this:
old thermostat
x=light blue
w3=pink
w2=white
l=grey
r=red
g=green
o=orange
y=yellow
e=brown
b=nothing/empty
air handler
w2=pink
w1=2white wires
o=empty
y=empty
g=green
r=red
c= light blue and blue
condenser
c=blue
y=yellow
o=orange
w2=white
r=red
e=brown
cant figure out how to wire up light blue, grey, and pink. Pink is wired to w3 on old thermostat and to w2 on air handler? My new thrmostat doesnt have a w3 connection! Any suggestions ??
Old 02-18-2012, 08:16 PM   #5
took pics with phone, and i keep getting message telling me that pic exceeds 100kb size.
Old 02-18-2012, 08:18 PM   #6
An old Tradesmen
Post model number of new thermostat.
Old 02-18-2012, 08:18 PM   #7
AKA HVACTECHFW
what model new thermostat do you have? L is HP fault...and is not necessary on new stat. X = C. pink is going to vary depending on the model of the new thermostat. Need the stat info before we can tell you how to wire it.
IT IS WHAT IT IS
Old 02-18-2012, 08:19 PM   #8
AKA HVACTECHFW
did you see my previous post about uploading them to a free online photo sharing site?
IT IS WHAT IT IS
Old 02-18-2012, 08:23 PM   #9
lets see now....
Old 02-18-2012, 08:28 PM   #10
lets see now....
Old 02-18-2012, 08:31 PM   #11
ok, im getting better at this.....i didnt think about jotting down the model number of new thermostat but i will be working there sunday and will take more pics and take more notes with detail, sorry about that.
Old 02-18-2012, 08:34 PM   #12
AKA HVACTECHFW
is the air handler variable speed? if so it will need O and Y installed to the board.
IT IS WHAT IT IS
Old 02-18-2012, 09:37 PM   #13
the second pic is of the air handler so i dont think its variable speed since there is nothing attached to o and y on circuit board in air handler. there are orange and yellow wires attached to o and y on circuit board in condenser though.
the model number of new thermostat is RCT8102A
Old 02-18-2012, 09:48 PM   #14
also, why does new thermostat have 8 terminals for wires but old thermostat has 9 wires out of 10 terminals used?
Old 02-18-2012, 11:40 PM   #15
See wiring diagram
RCT8102A Manual
old thermostat
x=light blue Common for 24vac, Not used on new thermostat
w3=pink Not used on new thermostat
w2=white Aux terminal on new thermostat
l=grey ?
r=red R terminal on new thermostat
g=green G terminal on new thermostat
o=orange O/B terminal on new thermostat. Need to setup function 2 on new thermostat
y=yellow Y terminal to condensing unit
e=brown Electric heat. Need to know mod number and manufacture of condensing unit
b=nothing/empty N/A
air handler
w2=pink White wire to W2 on condensing unit
w1=2white White wire to Aux terminal on new thermostat
o=empty N/A
y=empty N/A
g=green Green Wire to new thermostat G terminal
r=red Red wire to new thermostat R terminal
c= light blue and blue Light blue not used on new thermostat / Blue wire to condensing unit C terminal
condenser
c=blue Connect to AHU C terminal
y=yellow Connect to new thermostat Y terminal
o=orange connect to new thermostat O/B terminal
w2=white Connect to AHU W2 terminal
r=red Connect to AHU R terminal
e=brown Need to know condensing unit Mod number and manufacture.
thermostat is offline   Reply With Quote
Honeywell RTH111 Thermostat justplumducky HVAC 8 06-11-2011 12:14 PM
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 07:22 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
