Honeywell Th6000 Series Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 08:09 PM   #1
honeywell th6000 series thermostat
Just had a new air conditioner put in, along with a honeywell th6110d1021 thermostat. When I set the temp for, say 75 (cooling), the unit (heat pump) runs for approx 5 minutes, then shuts off for 5minutes, etc. This therefore runs off and on 6 times per hour. The cph is set for 3. Shouldn't the unit run just 3 times per hour with the cph set at 3?
Az Dan is offline   Reply With Quote
Old 07-20-2010, 12:05 PM   #2
An old Tradesmen
Rewards Points: 7,274
A/C may being cycling on a safety, not eh thermostat.
Old 07-20-2010, 05:38 PM   #3
Originally Posted by beenthere View Post
a safety
Which by that you mean some overload sensor in the system? Which one is likely?
Does it just mean high amb. temps. or a defect?
Old 07-20-2010, 06:45 PM   #4
An old Tradesmen
Could be a couple different things.
OP, needs to provide more info.
Old 07-20-2010, 06:54 PM   #5
No. 3cph setting does not lock the system out so it can't run more then that. Just as an example, not the real numbers, say your stat is set on 76. A 3 cph might turn the system on at 76.1 and off at 75.2 while a 9 cph might be 76.1 and 75.6. It's going the cycle when it needs to, the cph just adjust the droop between on and off.
Old 07-20-2010, 07:06 PM   #6
An old Tradesmen
CPH, is only accurate, at 50% load.
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 01:30 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
