Honeywell TH6000 Series T-stat - HVAC - DIY Chatroom Home Improvement Forum
Old 08-22-2010, 02:07 PM   #1
Honeywell TH6000 series t-stat
It appears my new t-stat is registering 2+ degrees lower than actual air temp near unit. Checked with 1 digital and 1 analog thermometer. Both indicate 2+ error.
Is this normal, not typical or alien intervention?
Can it be fixed/reprogrammed or needs to be replaced?
remnam is offline   Reply With Quote
Old 08-22-2010, 02:10 PM   #2
An old Tradesmen
Rewards Points: 8,228
I guess you mean then the actual air temp at the thermostat?
Are you sure no cold air from a supply register is hitting it, or the wall its mounted on.
Old 08-22-2010, 02:52 PM   #3
Thermometers are sitting on top of t-stat. So same air temp that is being registered by t-stat is hitting other 2 thermometers, since they are within a few inches of each other. Can't be much difference. Certainly not 2 degrees. Unless the Honeywell cools the air as it enters the t-stat air port/vent before it gets to the temp sensor?
Old 08-22-2010, 03:10 PM   #4
An old Tradesmen
The Honeywell mounted to the wall does sense the wall temp.
Your could be defective. Is the hole in the wall where the wires come through sealed.
Old 08-22-2010, 03:48 PM   #5
Well usually there is a fudge factor in most all thermostats, usually they will claim + - 2 degrees or some other number, I would imagine this thermostat is no different, so the 2 degree difference is probably legitimate.
Dujulan is offline   Reply With Quote
Old 08-22-2010, 05:27 PM   #6
An old Tradesmen
The TH series doesn't have a fudge factor built into it. Or else there would be no use to saying it maintains temp to within 1.
honeywell th6000 series thermostat Az Dan HVAC 5 07-20-2010 07:06 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 08:33 AM
Honeywell stat wiring w/ Trane furnace JaePee HVAC 7 01-18-2009 06:50 AM
LUX digital stat Trane XE80 intermittant problem rossl56 HVAC 6 12-26-2008 05:53 AM
Which Stat for New Carrier 58 MV Chemist1961 HVAC 10 12-21-2008 06:35 PM
