Honeywell TH5220D1029 Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 01-09-2011, 09:16 AM   #1
Honeywell TH5220D1029 issue
Hi all,
I just installed a Honeywell thermostat and I'm having a problem with the set point adjusting itself. Meaning it is running continously and I have it set at 72 degrees and once it maintains that temperature it never turns off.
Any thoughts?
jolicota is offline   Reply With Quote
Old 01-09-2011, 11:48 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
do you have a 80% or 90% eff. furnace? 80 set cph to 4 or 5 90 set cph to 2 or 3
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-09-2011, 01:59 PM   #3
An old Tradesmen
Rewards Points: 6,836
Its common for that stat to run the heat for several minutes after the display reads the set temp. Due to the displayed temp being rounded up.
Old 01-10-2011, 07:35 PM   #4
Thanks so much! We've decided to call a professional. It will never turn off no matter what. I have a carrier heat pump. I appreciate you all responding!
Old 01-11-2011, 03:09 AM   #5
An old Tradesmen
Your welcome.
Remember. if the outdoor temps are low. Most heat pumps won't shut off.
Honeywell TrueSteam wont work! Stewart Daniel General DIY Discussions 18 12-20-2010 07:41 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 08:33 AM
carrier furnace and honeywell zone control issue bmccarron HVAC 14 09-20-2009 09:59 AM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
