Old 01-13-2013, 06:20 PM   #1
honeywell TH4110D1007 thermostat
My ac is working and the digital display and backlight is on but when I press the up and down arrows the temperature will not change it is staying on 78. I tried changing the battery and still have the problem. Central air conditioning in Florida.
pashley is offline   Reply With Quote
Old 01-13-2013, 08:11 PM   #2
Professional
sounds like you need a new thermostat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-14-2013, 07:49 PM   #3
I am replacing the old Honeywell TH4110D and the wires connected are
W White
Y Yellow and white
G Green
O no wire
Rc red
R red with the Rc and R has jumper in
B and C no wire
Have bought a new Honeywell RTH6350D 5.2 day
These wires show a Y2, W2, G, W, Y, R and Rc
My question now is should I put wires the same as old with a yellow and white on the yellow or put one white on the W2.
Old 01-14-2013, 08:19 PM   #4
One of the reds to R and the white to Y must be part of 2 wire feeding to some dedicated circuit.
Hvacwin is offline   Reply With Quote
Old 01-14-2013, 08:21 PM   #5
Professional
Wire it the same as the old.
IT IS WHAT IT IS
Old 01-14-2013, 08:21 PM   #6
Could use a picture of the wires where they meet at the unit
Old 01-15-2013, 06:17 AM   #7
DiYRegular's Avatar
It really seems like you need a new thermostat because your current one can't detect temperature.. or change it.. hm..... at least I guess so.
DiYRegular is offline   Reply With Quote
Old 01-15-2013, 07:16 PM   #8
Talking
Thanks to all. Replaced it with the new Honeywell and attached wires same as old one. Everything seems to be working okay.
Thank you for all the help.
Honeywell / Honeywell thermostat replacement question. FatBear HVAC 12 10-24-2012 01:41 AM
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 07:22 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
