-   -   Honeywell T8600D Chronotherm installation (http://www.diychatroom.com/f17/honeywell-t8600d-chronotherm-installation-4584/)
sasquatchbreath 10-31-2006 10:52 AM
I replaced my low tech trane thermostat with a Honewell T8600D Chronotherm IV this weekend. I have a forced air gas furnace and electric central AC
It seemed like an easy install, like wires to like wires/conectors. It went off without a hitch and I enjoyed a warm consistant temp house on a blustery saturday night.
Sunday was unusually warm. Uh oh. the AC will not turn on.
I tried in the programs, cleared the programs and tried to manually turn it on etc. The snowflake comes on the display, I hear a click, but no compressor, no fan etc.
Heat works fine.
Any thoughts?
#CARRIERMAN 10-31-2006 11:26 AM
Hi sasquatchbreath
The particular thermostat you have if I am not mistaken has two different Y circuits, you will need to go back to your wiring diagram that came with the new stat and find out wich one is to be used for single stage cooling. If you have any further questions, let us know.
Rusty
sasquatchbreath 10-31-2006 11:31 AM
You had me excited about a possible easy fix, but...
the conectors are Y G O B W R
#CARRIERMAN 10-31-2006 11:38 AM
Hi sasquatchbreath
Can you let me know how you have thermostat wired, and did you configure thermostat for proper operation. Any further questions let me know and I will walk you through it.
Rusty
sasquatchbreath 10-31-2006 11:48 AM
cool. I appreciate the help. I'm at work now but will take a look and post.
I'm in KC and noticed you are in KS. Its not a rush to get the AC working, but I'm the type that likes things just so :)
Thanks - Tim
sasquatchbreath 11-01-2006 09:35 AM
OK - More info
the thermostat has the following terminals O G Y W RC R
I wired as follows:
Green Wire to G
Yellow Wire to Y
White Wire to W
Red Wire to R
Exactly as the wires were attached to the old cheapo thermo.
I did not change anything from manufacturer specs. In looking at the installation instructions I don't see anything I think I should change (ignorance is bliss) that would help except maybe the minimum off time which I think shouldn't matter since it has not been on.
One other strange issue withthe thermo. is that it should have heat, Off, Cool, and Auto as options. I do not get auto as an option.
Any help you can give me is great. If I have to call someone in fine, but I'm kind of stubborn and can't help but think it is something simple.
Thanks - Tim
#CARRIERMAN 11-01-2006 12:07 PM
Hi again sasquatchbreath
I think you have probably by now figured out your problem. But if not, is there a wire running between R & RC. If there is not one use a short piece of thermostat wire and put it between the two terminals. You should be good to go after that. Let me know if that works. I live in Independence, KS.
Good luck
Rusty
sasquatchbreath 11-01-2006 01:25 PM
Are you saying the AC will not work unless I give it power?
I kinda figured I may need to connect the r and rc but wasn't sure enough to just do it.
I'll try tonight and let you know but I'm betting it will work.
Thanks a bunch
Tim
#CARRIERMAN 11-01-2006 07:36 PM
Hi sasquatchbreath
I knew you would figure it out. And I will bet it works also. Have a safe and warm winter.
Rusty
sasquatchbreath 11-02-2006 03:15 PM
Thank you sir
and yes it did work
