Honeywell T8011R1006 Programmable Digital Thermostat-No Display - HVAC - DIY Chatroom Home Improvement Forum
Old 08-25-2012, 12:27 PM   #1
Honeywell Model t8011r thermostat no display. Power went out a couple of days ago, I reset the breaker and the display came back on but each time I set the time it would reset. I removed the thermostat to see if there was a fuse. After I realized there was no fuse I put back the thermostat and now there is no display at all. Unit is coming on. Any ideas? Thank you in advance.
wperea is offline   Reply With Quote
Old 08-25-2012, 01:21 PM   #2
An old Tradesmen
Rewards Points: 8,154
Probably had a surge when the power went out or came back on. Good chance its time for a new stat.
The Following User Says Thank You to beenthere For This Useful Post:
wperea (09-06-2012)
Old 09-06-2012, 05:34 PM   #3
So I replaced the stat and the 5amp fuse in the air handler and still no digital display. Fan comes on and the a/c comes on. Unfortunately I still cannot see the temperture setting. Any other suggetions?
Old 09-06-2012, 06:00 PM   #4
An old Tradesmen
Brand and model number of new thermostat.
Old 09-06-2012, 06:06 PM   #5
Same Brand & Model.
Old 09-06-2012, 06:16 PM   #6
An old Tradesmen
The 8011 wasn't a real popular model, which is partially why its a discontinued model. Since its working the A/C and heat. Take that one back, and get a different model.
A loose connection at the furnace could cause it not to work, but generally never caused them to work without a display.
wperea (09-06-2012)
Old 09-06-2012, 06:26 PM   #7
Same Brand & Model.
Guess what beenthere? It has been nearly an hour since I replace the stat and it literally just came on and the display is working. YOU ARE AWESOME! I can't thank you enough.
Old 09-06-2012, 06:30 PM   #8
An old Tradesmen
Wish i had actually helped you.
That model stat, ws one I used for a while when it first came out. It was a cost effective stat. But had a fair number that died in just a year or 2. Hope yours last a good long time.
Old 09-06-2012, 06:41 PM   #9
You did. Your first answer was spot on.
Old 09-06-2012, 07:45 PM   #10
An old Tradesmen
Thank you.
Just because your stat, A/C, and heat is working. Doesn't mean you can't hang around. We also have a general and an off topic forum. For all kinds of conversations, along with many other forums you may find usefull.
Old 09-06-2012, 07:52 PM   #11
I'm Your Huckleberry
Rewards Points: 2,270
Get a room. LOL!!!!!!
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-06-2012, 07:56 PM   #12
An old Tradesmen
Tags
honeywell thermostat
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 06:22 PM
Question on installing an Honeywell RTH6350 programmable thermostat. outdoorted HVAC 3 01-02-2011 06:48 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 08:33 AM
Honeywell RTH8500 Programmable Thermostat not reaching scheduled temp- HELP :[ Tramlo HVAC 4 01-18-2009 08:12 AM
