Honeywell Slant/fin Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 03:10 PM   #1
Question
Honeywell slant/fin boiler
Furnace keeps kicking off when boiler temperature reaches between 160 and 170 degrees F. The PSI stays at 15 and doesn't seem to be the problem. Does anyone know what might be causing this and what I need to replace to get it fixed?
C. Hurt is offline   Reply With Quote
Old 11-11-2011, 03:59 PM   #2
how
Rewards Points: 1,070
The temp operating controls are just doing there job. Temps much above this range are just going to be causing problems for you.
Sounds like it's running the way it's supposed to.
By "KIcking off" do you mean that just the main gas burners turn off untill the water temp drops back below 150F but the pump continues to run with the thermostat calling for heat?
Are you not getting the heat you want, where you want it?
how is offline   Reply With Quote
Trying to wire Honeywell IAQ to Burnham RSM/96 oil boiler 6burgh HVAC 26 11-13-2010 09:21 PM
Honeywell L8124L Settings on Oil Boiler shawnmd HVAC 1 10-24-2010 08:11 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
rusty restoration ; Peerless boiler and Honeywell 8124 controller, arthurheyman Plumbing 1 08-25-2010 06:42 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 05:21 PM
