Honeywell Screen Went Blank - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 10:22 AM   #16
Topic Hunter
Focker's Avatar
Rewards Points: 79
I have a 5 year parts & labor warranty from the installer...I really want to keep my hands out/off of it. I have in my hands a no charge invoice clearly stating he replaced the 3 amp fuse with a 5 amp.
Originally Posted by hvactech126 View Post
Your tech is a moron. Many systems come with a 3A fuse. Put the correct fuse back in there before you blow your transformer.
The transformer at the curb?
Originally Posted by biggles View Post
...condensate pump might if you have one see if you have low voltage wires going to it
I have the pump but it's not wired to the system.
Focker is offline   Reply With Quote
Old 06-26-2012, 10:39 AM   #17
AKA HVACTECHFW
Rewards Points: 1,208
The transformer in your air handler/furnace.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-26-2012, 02:35 PM   #18
An old Tradesmen
Rewards Points: 7,328
A 40 VA transformer at 24 volts has a max continuous amp draw rating of 1.66 amps. The 3 amp protected the 40 VA transformer from surges. The 5 amp won't.
Old 06-26-2012, 05:00 PM   #19
Topic Hunter
Focker's Avatar
Rewards Points: 79
Good to know...Sounds like I better make a call.
Old 06-28-2012, 10:34 AM   #20
Topic Hunter
Focker's Avatar
Rewards Points: 79
Well the 5A fuse popped last night. I called at 3am and left a msg so I could be at the top of the list today. A tech should be here this morning.
Sent from my mobile using DIY chat room app.
Honeywell TrueSteam wont work! Stewart Daniel General DIY Discussions 18 12-20-2010 07:41 AM
Replace Trane Weathertron (Baystat 339) with Honeywell RTH2410 ammiller2 HVAC 0 12-12-2009 09:50 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 08:33 AM
Help for a locked screen on a Honeywell TH8320 thermostat TanyaMendenhall HVAC 3 06-15-2009 10:05 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
