Honeywell S8600 Wiring - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 04:40 PM   #16
I'm Your Huckleberry
Rewards Points: 2,270
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-03-2012, 04:46 PM   #17
AKA HVACTECHFW
Rewards Points: 1,208
splice this wire for C!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-03-2012, 07:36 PM   #18
Rewards Points: 22
do i still need a ground wire or will it just be a 3 wire hook up.
bdp1999 is offline   Reply With Quote
Old 05-03-2012, 08:23 PM   #19
Rewards Points: 22
when i splice it at the boiler, where do i plug in the second part.
Also, just to make sure i have a clear understanding. Splicing is when you split the wire in two or is it just when you cut it and use a connector in the middle of it.
Old 05-03-2012, 11:50 PM   #20
AKA HVACTECHFW
cut the wire, strip both sides and new wire and wire nut all 3 together.
IT IS WHAT IT IS
Old 05-04-2012, 08:00 AM   #21
Rewards Points: 22
After that, just take the new wire to the C connection on the thermostat? Also should I be splicing it at the boiler and running it or can I make it easy and simple by just doing it behind the thermostat? Wouldn't a Jumper do the same thing or would it be dangerous going across so many other connections?
Thanks for all your help, I just want to make sure I get this right so that I don't blow out my boiler.
Old 05-04-2012, 10:53 AM   #22
Rewards Points: 22
this is my impression of what you want me to do...
24v/ground wire
splice 24v/g wire
boiler==cut==========================thermostat
boiler==----- -------=====================thermostat
add new wire, making it 3 wires combined and connect them
run that wire along side the other wire and hook it to the C wire slot on the thermostat
so all in all, I'm just adding one more wire to the thermostat and boiler?
Old 05-04-2012, 11:18 AM   #23
AKA HVACTECHFW
R and w wires existing to stat? Need a third wire to C @ stat from splice.
IT IS WHAT IT IS
Old 05-04-2012, 06:05 PM   #24
Rewards Points: 22
is the 24v/g wire the w wire? I think i messed up. do I actually need to run it from where you put the arrow all the way to the stat? I spliced the w wire at the stat and ran it over to the c connection. it came on, but the boiler started making a ticking noise. What should i do now?
Old 05-04-2012, 07:35 PM   #25
AKA HVACTECHFW
Yes... you need a additional wire from the splice all the way to the stat. I dont know why you don't listen. I'm done
IT IS WHAT IT IS
Old 05-04-2012, 08:19 PM   #26
Rewards Points: 22
ok, i guess i'll be trying it again. If i get the 5 line wire will i just be able to use that one instead of the two i already am running?
Current : 1- 2 line wire and 1-1 line wire
or
Changing it to: 1- 2 line wire and 1-5 line wire(hopes of removing the 2 line wire
or
1- 5 line wire
Old 05-05-2012, 01:39 AM   #27
Rewards Points: 22
i did as you explained, but no wifi tower is showing up on the thermostat. What do i do now or am i missing something?
Old 05-05-2012, 05:14 AM   #28
An old Tradesmen
Rewards Points: 7,816
Post pic of the wiring at the s86, and one of the transformer.
The more we can see, the better we know how your system can be wired.
Old 05-05-2012, 07:28 AM   #29
Rewards Points: 150
So you got the thermostat up and running? You want to connect the wifi now?
kilosos2 is offline   Reply With Quote
Old 05-05-2012, 09:38 AM   #30
Rewards Points: 22
my newest update. this is what things look like now....
wiring diagram of Honeywell VisionPro IAQ ochir Electrical 1 03-27-2011 09:02 PM
T-Stat Wiring - Lux TX9100e replaces Honeywell T8411R for Carrier Heat Pump/Cooling 99Problems HVAC 1 08-19-2010 01:44 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
