Honeywell RTH8500 Spare Contacts? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2008, 12:25 PM   #1
Honeywell RTH8500 spare contacts?
Hi,
I am wondering if anyone knows if there is a spare set of contacts on the Honeywell RTH8500 thermostat. I have an air to air exchanger that I would like to turn on only when the furnace kicks in.....instead of running constantly.
golfnut65 is offline   Reply With Quote
Old 11-18-2008, 01:06 PM   #2
Originally Posted by golfnut65 View Post
Hi,
I have an air to air exchanger...
Do you mean an HRV or ERV unit?
Hi,
...that I would like to turn on only when the furnace kicks in.....instead of running constantly.
Do you mean whenever the fan runs, or just heat and cool?
dac122 is offline   Reply With Quote
Old 11-18-2008, 01:31 PM   #3
Fan on
Hi,
I would like it to come on in either mode.....when heating or if the furnace fan comes on. I only run the air exchanger in the winter, so probably only when the heat comes on.....but if the heat kicks in, the furnace fan runs as well.
Old 11-18-2008, 01:42 PM   #4
Then I think it could be energized or switched from either the tstat or air handler depending on what you have. If you just want to know if its possible to hire someone else then I think so, but if you want to diy we're gonna need a whole lot more info such as: what exactly is the unit, and how is it switched now; what type of air handler do you have and how is it controlled now; and anything else you can think of?
Old 11-18-2008, 01:48 PM   #5
more details
It is a Lennox furnace....and a Lennox HRV unit. The HRV has it's own humidstat. So, the HRV will continue to run to try and satisfy the humidity in the house even though the furnace is not running. I think it would make more sense to have the two interact and only kick in when it calls for heat.....and more energy efficient. After all, the HRV mixes with the return air.
Old 11-18-2008, 03:47 PM   #6
seems like unit should be wired the other way around so that the exchanger runs the furnace fan as needed not the other way round the
easy answer is wire it to the fan terminal in the airhandler,however dont have enough info to say that will even work.the xcange. would have to derive its low voltage from the furnace to begin with. assumeing its controlled by low voltage
kennzz05 is offline   Reply With Quote
Old 11-18-2008, 03:53 PM   #7
Xchange running
Ken,
That does make sense doing it that way. I'll have to check into the voltage to see if they can even be used as common together. I was just hoping that the thermostat would have an empty set of dry contacts to break the xchanger power....like an auxillary set.
Old 11-19-2008, 03:41 AM   #8
An old Tradesmen
Rewards Points: 7,400
Are you trying to humidify, or dehumidify, withe HRV.
HRV's don't add humidity in the winter. Unless its extremely humid outside.
Old 11-21-2008, 10:14 AM   #9
I figured it out
I finally have it working how I want. Now the furnace fan will run when the HRV is on. I use it to dehumidify the house so condensation does not form on the windows.
RTH8500 Wiring O and B Terminals dermanj HVAC 19 06-05-2016 02:55 PM
help with installation of Honeywell RTH8500 thermostat dg xy HVAC 19 07-28-2009 12:25 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
help with installation of Honeywell RTH8500 thermostat dg xy Electrical 2 11-13-2008 07:03 PM
