Honeywell RTH8500 Programmable Thermostat Not Reaching Scheduled Temp- HELP :[ - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2009, 12:41 AM   #1
Unhappy
Honeywell RTH8500 Programmable Thermostat not reaching scheduled temp- HELP :[
Please HELP
I have had a few service techs out here to look at the furnace.The FIRST problem was the furnace would only "kick in" when it felt like it.
The first one blamed relays being a little dirty, blew on them and it was ok again for a few weeks.He thought it was the blower but eliminated that for some reason...
Second guy blamed the circuit board for 300.00 and replaced it- THAT problem disappeared and then this new nightmare started
NOW, the furnace will not heat up to the scheduled temp of 70, it goes to about 65 or 64 or so and that is it until I turn the on/off switch off and back on- sometimes several times- very annoying.
This tech blamed my brand new expensive programmable thermostat which worked fine- so I bought a brand new one....same problem. Crossed some wires or blah blah to see what it was and still I think- he has no idea. This started after the board was replaced by HIS tech and he is saying there is no way that is the problem- they would have nothing to do with each other. He opened the back of the furnace, pointed to some part at the back, told me to unscrew it, take it to Lennox and get a new one.
OMG - seriously
Does anyone out there with any smarts have any idea what this is?
PLEASE HELP, I could have bought a high efficiency furnace by now with what I have had to spend in this 10 yr old Lennox piece.I am a girl and the thought of taking off the back of it and taking out screws ascares the crap out of me- I have 2 small children in here who need heat- it gets to minus 46 here- please help.
Thanks !
Tramlo is offline   Reply With Quote
Old 01-05-2009, 07:09 AM   #2
An old Tradesmen
Rewards Points: 8,236
Don't know what part you are refering to.
Although there are many techs qualified to work on Lennox equipment, that don't work for a Lennox dealer.
Quite often, your better off using a Lennox dealer.
They of course have better access to the OEM parts.
Post the model number of your furnace. It will be inside the panel.
Old 01-06-2009, 12:12 AM   #3
Thank you for responding but I am not sure what you are referring to?
If I knew what part was causing the problem, I would have had it repaired a long time ago- none of the techs even know- some blame the thermostat that is brand new or they charge me 300.00 + to keep replacing parts on my 10 yr old furnace that still don't fix this issue.
This all started once they replaced the "board" on it and they are denying that the issues can be or are related.
If anyone has had this situation before please let me know what it is- it is costing me 125.00 per service call just to keep getting the run around.
What would cause this ???
Old 01-06-2009, 04:17 AM   #4
An old Tradesmen
Thats why I asked you to post the model number.
It could be a dirty air filter.
Or, a dirty A/C coil causing the high limit to shut the furnace down.
Along with blocked or cover registers.
Or, a dirty flame sensor.
You should use a Lennox dealer.
Some Lennox furnaces, have problems, that are only related to Lennox.
Old 01-18-2009, 08:12 AM   #5
Angry
Installing Honeywell RTH8500 to replace Johnson control T210hp-10
It should be simple, that's what they claim.....
The wire coming from the wall are labelled as follow:
R
O
Y1
C
X
W2
I used the wiring diagram from page 12 (Installation Guide) that says:
R connect to Rc & R leave metal jumper in place,
O to O/B
Y1 to Y
C to C
X to E
W2 to Aux
Power back heat pump and furnace, set time and temp, doesn't work!!!!
Now i have to go back to JC if I want heat in house (it's -12C outside)
Thanks in advance... I leave computer on to heat up the house
Can't set date, only time, so I am on Wednesday, and year is not available...
Pierre M is offline   Reply With Quote
help with installation of Honeywell RTH8500 thermostat dg xy HVAC 19 07-28-2009 12:25 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
help with installation of Honeywell RTH8500 thermostat dg xy Electrical 2 11-13-2008 07:03 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
