Honeywell RTH7600 Program Issues - HVAC - DIY Chatroom Home Improvement Forum
Old 07-16-2010, 11:20 PM   #1
Question
Honeywell RTH7600 program issues
Installed a new thermostat, system works properly but unable to set the 4 different program schedules to work. Wake time set 5:45 temp a/c 82, leave time 2:00 temp a/c 75, return 2:45 temp 85, sleep time set to 81. Electric rates the most at 3 to 6, so I want to pre-cool house 45min prior than higher temp so a/c doesnt run dureing on peak hrs. I have set this for 5 days a week with a different settings for sat,sun. the RTH 7600 doesnt work? not sure what programing I'm missing. Is there a max temp differnce that a 10deg is outside its limits? I've tried reset, removing batteries,turning breaker on and off. At my wits end. Any thoughts out there
mbmike is offline   Reply With Quote
Old 07-17-2010, 06:06 AM   #2
biggles's Avatar
each day has to be programmed or do the copy instruction step.make sure actual time/day is up,and watch the AM/PM s it sounds like your missing hitting copy to take day/time..
Old 07-17-2010, 07:07 AM   #3
An old Tradesmen
Rewards Points: 6,132
What do you mean by, doesn't work?
It doesn't turn your A/C on or off.
Or that the house isn't cooled to those temps by that time.
10 decrease in temp. Can take a long long time. Some systems may take 12 hours to do that on a hot day. And only 2 hours on a cool day.
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
Replace Trane Weathertron (Baystat 339) with Honeywell RTH2410 ammiller2 HVAC 0 12-12-2009 10:50 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 09:33 AM
Help Needed - Program Honeywell Prestige Thermostat hennyh HVAC 2 11-19-2009 06:59 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
