-   -   Honeywell RTH7600 program issues (http://www.diychatroom.com/f17/honeywell-rth7600-program-issues-76393/)
mbmike 07-16-2010 10:20 PM
Installed a new thermostat, system works properly but unable to set the 4 different program schedules to work. Wake time set 5:45 temp a/c 82, leave time 2:00 temp a/c 75, return 2:45 temp 85, sleep time set to 81. Electric rates the most at 3 to 6, so I want to pre-cool house 45min prior than higher temp so a/c doesnt run dureing on peak hrs. I have set this for 5 days a week with a different settings for sat,sun. the RTH 7600 doesnt work? not sure what programing I'm missing. Is there a max temp differnce that a 10deg is outside its limits? I've tried reset, removing batteries,turning breaker on and off. At my wits end. Any thoughts out there:furious:
biggles 07-17-2010 05:06 AM
each day has to be programmed or do the copy instruction step.make sure actual time/day is up,and watch the AM/PM s it sounds like your missing hitting copy to take day/time..
beenthere 07-17-2010 06:07 AM
What do you mean by, doesn't work?
It doesn't turn your A/C on or off.
Or that the house isn't cooled to those temps by that time.
10 decrease in temp. Can take a long long time. Some systems may take 12 hours to do that on a hot day. And only 2 hours on a cool day.
