Honeywell RTH230B Thermostat Trouble - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 12:30 PM   #1
********** please ignore this post - it is now resolved *************
it seems that the fuse box tripped and that's what the problem was
i just installed rth230b to replace the old dial version thermostat we had. This is the manual for it. http://dl.owneriq.net/3/39359643-dfd...8eecddd9fc.pdf
background: The new thermostat is actually about 3 years old (we had it installed a while ago but it seemed to be acting flaky, so we went back to the older dial/mercury version, which worked more reliably). Then when the older dial one started flaking out too, we called in an ac guy and he actually replaced a capacitor that had burned out on the ac system. The ac system started up immediately and worked. However, we never went back and reinstalled the newer programmable digital version of the thermostat...until today. It's a 4 wire hookup. I hooked up all the wires appropriately, r to rh, w to white, g to green and y to yellow. I went to the thermostat and turned it to on (not auto) and to cool. Nothing. It's not spinning up the fan. Checked and replaced the 2aa batteries and still nothing.
Am i to assume the thermostat is broken?
The other background info is that even on the dial version thermostat... I have to turn it to on instead of auto. Auto setting doesn't seem to turn the unit on. Weird?
Last edited by sdambra; 07-14-2012 at 12:37 PM. Reason: IT SEEMS THAT THE FUSE BOX TRIPPED AND THAT'S WHAT THE PROBLEM WAS
sdambra is offline   Reply With Quote
Can you help me find a replacement thermostat? Having trouble! chicy724 HVAC 68 05-14-2013 10:44 AM
New Honeywell thermostat connected to old Climatrol heat pump olorintf HVAC 0 08-24-2010 09:52 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Need help with Honeywell thermostat mmspar HVAC 1 06-29-2010 10:29 PM
Totaline thermostat trouble shooting Goldwing93 HVAC 3 07-30-2009 10:35 PM
