Honeywell RTH Programmable Thermastat - HVAC - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 09:23 AM   #1
Trying to install Honeywell RTH 7500 programmable thermastat to control multistage Heil heat pump. The current thermastat has a "W2" wire. The 7500 wiring connections are set up for either "conventional" or "heat pump". There is a W2 connection on the convential side of the programmable thermostat but not the heat pump side. Can this wire be connected to the W2 convential connection?
Thanks,
jimirit
Honeywell RTH Programmable Thermastat-heil-info.jpg   Honeywell RTH Programmable Thermastat-current-stat.jpg   Honeywell RTH Programmable Thermastat-rth-7500-wiring.jpg
jimirit is offline   Reply With Quote
Old 02-15-2010, 11:26 AM   #2
Rewards Points: 6,652
It will work, just make sure that you set the thermostat up properly when programming it, that it is on a Heatpump system. All the back plate is, is a mounting place for the wires, and the thermostat to hang off of.
Old 02-15-2010, 05:20 PM   #3
Thanks...it worked. I hooked up the W2 to the W2 for conventional or AUX for heat pump. I also called the Honeywell tech support hotline. They confirmed this is the correct config and provided additional setup info.
Old 02-15-2010, 06:38 PM   #4
Didn't you get a set of books with it?
Old 02-16-2010, 06:30 AM   #5
yes...book says that if there is a W2 wire w/ heat pump to have installed by professional.
Replace Trane Weathertron (Baystat 339) with Honeywell RTH2410 ammiller2 HVAC 0 12-12-2009 10:50 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 09:33 AM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Honeywell RTH8500 Programmable Thermostat not reaching scheduled temp- HELP :[ Tramlo HVAC 4 01-18-2009 09:12 AM
honeywell T6360 thermastat twilightflyer Electrical 4 09-10-2008 09:26 AM
