Honeywell R7284 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2013, 02:14 PM   #1
honeywell r7284
I have a honeywell oil primary control. I know its an R7284u1004..All I need is someone to tell me how to program a "post purge" on it..Isn't there some kind of blower fan delay that i can set on it to blow out the smoke exhaust from the flexible direct vent pipe so that the smoke doesn't leak into my basement once the burner shuts off?
big ted is offline   Reply With Quote
Old 12-11-2013, 04:42 PM   #2
An old Tradesmen
Rewards Points: 6,124
You have another problem besides needing a post purge.
So your oil burner is vented out the side of the house? Is there a power venter on that wall?
Old 12-12-2013, 08:54 AM   #3
r7284 primary control/oil burner
Yes, it is vented on the side of house but the there's no power vent out there but since it is direct vent, there is an internal blower to support the exhaust and a fresh air intake..It's always been a piece of crap and I will be buying a 500 gal propane tank and switching to a direct vent propane boiler next year..
Old 12-12-2013, 04:54 PM   #4
An old Tradesmen
Hold the 3 buttons on the left in at the same time for 2 to 5 seconds. It will enter installer set up. Third screen or so will be burner off delay.
Old 12-12-2013, 05:26 PM   #5
R7284 primary control
Thanks alot for your time sir..The only 3 buttons on this control are an up arrow button, a down arrow button, and an i button underneath those 2..Honestly, I held the 3 of them in, making sure I press hard on them and the screen is still blank..I held for 6 or 8 seconds..I'm wondering if I need to do this when it calls for heat to get to the installer menu
Old 12-13-2013, 01:08 AM   #6
An old Tradesmen
No, it should should go into installer set up when you push those 3 buttons in at the same time for 2 to 3 seconds as long as it has power. They would be the up arrow, down arrow, and I button.
Old 12-13-2013, 11:28 AM   #7
Ok thanks man..you've been great..Yes I pushed all those buttons simultaneously and I get nothin..Unless theres some kind of lockout under the controller lid, it just will not program..Have a great Christmas..
Old 12-13-2013, 11:36 AM   #8
An old Tradesmen
No, holding all 3 buttons in is suppose to go to installer set up no matter what.
Good luck, and have a Merry Christmas yourself.
Old 12-18-2013, 10:50 AM   #9
primary r7284
Hey BEENTHERE, I got into the installer menu..I can only access it when the boiler is firing..There is a valve on delay setting which is set at 20 seconds, and a burner off delay which is set at 1 minute..Thats all I can find..unfortunately, when the unit stops firing, there is still no blower motor delay to purge out the heat and the exhaust smoke..
Old 12-18-2013, 09:52 PM   #10
An old Tradesmen
Is the L1 terminal of the primary always powered?
Old 12-19-2013, 09:36 AM   #11
It certainly looks that way to me..From the aquastat the black wire goes to the L1 terminal under the lid of the primary, the wh neutral goes to L2, and the red wire goes to the limit terminal..
Old 12-19-2013, 04:31 PM   #12
An old Tradesmen
So the display of the primary is active even when the aquastat is not calling for heat.
Old 12-19-2013, 10:47 PM   #13
No sir..The display only activates when there is a call for heat and that is exactly what gets displayed: "call for heat" I don't know maybe it's just acting weird.
Old 12-20-2013, 05:11 AM   #14
An old Tradesmen
Double check, if the black wire or the red wire is the constant power wire.
Honeywell / Honeywell thermostat replacement question. FatBear HVAC 15 05-05-2014 02:15 AM
Honeywell TrueSteam wont work! Stewart Daniel General DIY Discussions 18 12-20-2010 08:41 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
Replace Trane Weathertron (Baystat 339) with Honeywell RTH2410 ammiller2 HVAC 0 12-12-2009 10:50 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 09:33 AM
