Honeywell Q674L To RTH7600D Upgrade - HVAC - DIY Chatroom Home Improvement Forum
Old 10-06-2010, 06:13 PM   #1
ssn
Honeywell Q674L to RTH7600D upgrade
I have a heat pump with a Honeywell Q674L 1207 thermostat on it. The wiring on the current thermostat is
O, G, R, Y, a white wire to W2 which is jumpered to E and a brown wire to X.
What is the right configuration to replace the thermostat with the newer Honeywell RTH7600D? Thanks
ssn is offline   Reply With Quote
Old 10-06-2010, 06:23 PM   #2
Houston204's Avatar
Rewards Points: 556
O = O/B
G = G
R = Rc & R
Y = Y
W2 & E = Aux & E
X = C
option 170 = 7
option 190 = 0
Houston204 is offline   Reply With Quote
The Following User Says Thank You to Houston204 For This Useful Post:
ssn (10-06-2010)
Old 10-06-2010, 06:53 PM   #3
ssn
Originally Posted by Houston204 View Post
O = O/B
G = G
R = Rc & R
Y = Y
W2 & E = Aux & E
X = C
option 170 = 7
option 190 = 0
Thanks a lot. What I tried was
G = G
R = Rc & R
Y = Y
W2 & E = Aux
X = E
option 170 = 7
option 190 = 0
and it blew up the 5 amp fuse in the coil furnace . I am glad that was the only damage. Thanks a lot again.
Honeywell RTH7600D Thermostat brewmastr HVAC 1 01-03-2010 08:10 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 08:33 AM
Wiring a Honeywell ProVision TH8321U1006, upgrade from Weathertron Tstat drandersoninc HVAC 6 10-04-2009 03:20 PM
Upgrade RV analog with Honeywell Thermostat Ray Wallace HVAC 3 08-13-2009 12:34 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
