Honeywell Primary Control For Oil Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2012, 07:26 PM   #1
Honeywell primary control for oil heat
I have a Honeywell primary control.....I know the purpose of this control and its function but.....The one i have trips out and leaves the boiler running...the wiring is correct....I disconnected the CAD cell and it will still run.....The primary worked last season but i have never found one to fail in the closed position. Is it just a bad control or am I missing some thing?
patrickmhart is offline   Reply With Quote
Honeywell CT410B..will it work with ceiling heat too? shelzmike Electrical 3 10-10-2012 12:53 PM
auxilliary heat control JeanThomas HVAC 1 04-30-2011 10:29 AM
Air Source Heat Pump Lock-Out Control sydneysm HVAC 7 11-11-2010 05:58 PM
Help install Honeywell CM927 to Air to Water HeatPump Aermec ATC@LWSK HVAC 1 11-06-2010 06:54 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
