Honeywell Power Flow-through Bypass Humidifier, HE360A Question - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2009, 09:19 PM   #1
Hi all, I just purchased this unit and installed it. I have a question on the wiring side of it. I hooked the 2 black wires on the HUMIDISTAT straight to the HE360, and that pluged into 120 outlet. It works but it stays running all the time. My questionis did I hook it up right? If its wrong, how else should I have done it?
TIA
WGFA is offline   Reply With Quote
Old 03-04-2009, 11:00 AM   #2
HE360A install
Did you ever get this wired correctly? It should only run when your blower for your heat is running. Depending how you wired it directly to your unit or through the sail switch that came in the install kit. Here are some links I found showing the wiring. If you got it working have you noticed a difference in your house? I bought mine a week ago and its going in this weekend.
http://img399.imageshack.us/img399/6...9104438lm2.png
http://images.google.com/imgres?imgu...GL_en%26sa%3DN
TIA
reminvestor is offline   Reply With Quote
Old 03-04-2009, 11:41 AM   #3
Hey Thanks for the reply. Yes I figured it out and it is working great. Thanks for the links.
I bought the sail switch.
HVAC Humidifier Question rubicon789 HVAC 8 01-13-2009 11:06 AM
No power Question fburke Electrical 4 06-11-2008 03:56 PM
Furnace drum humidifier question justin76 HVAC 1 02-17-2008 08:45 PM
Aprilaire 700A Humidifier - Automatic control question feign3 HVAC 1 12-11-2007 04:31 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
