-   -   Honeywell Power Flow-through Bypass Humidifier, HE360A Question (http://www.diychatroom.com/f17/honeywell-power-flow-through-bypass-humidifier-he360a-question-38581/)
WGFA 02-17-2009 09:19 PM
Hi all, I just purchased this unit and installed it. I have a question on the wiring side of it. I hooked the 2 black wires on the HUMIDISTAT straight to the HE360, and that pluged into 120 outlet. It works but it stays running all the time. My questionis did I hook it up right? If its wrong, how else should I have done it?
TIA
reminvestor 03-04-2009 11:00 AM
HE360A install
Did you ever get this wired correctly? It should only run when your blower for your heat is running. Depending how you wired it directly to your unit or through the sail switch that came in the install kit. Here are some links I found showing the wiring. If you got it working have you noticed a difference in your house? I bought mine a week ago and its going in this weekend.
http://img399.imageshack.us/img399/6...9104438lm2.png
http://images.google.com/imgres?imgu...GL_en%26sa%3DN
TIA
WGFA 03-04-2009 11:41 AM
Hey Thanks for the reply. Yes I figured it out and it is working great. Thanks for the links. :thumbsup:
I bought the sail switch.
