Honeywell Personal Comfort Control - HVAC - DIY Chatroom Home Improvement Forum
Old 05-19-2012, 02:31 AM   #1
Has anyone ever had an issue with one of these "Honeywell Personal Comfort Control" devices where it keeps saying "No Signal" and can't seem to connect to thermostat? Anyone know how to get out of it?
Thanks.
djgrant is offline   Reply With Quote
Old 05-19-2012, 06:32 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
Replace the batteries, then you must set the wireless adapter into search mode and then push the snyc button on the control. DO you have a manual for your control system? If no then download one from Honeywell's site.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-19-2012, 06:25 PM   #3
I tried replacing the batteries already and I am not able to push the connect button on the control because there isn't a physical button. There is supposedly a touch button but it hasn't shown up yet. The "no signal" error seems to prevent it from getting to the next state where I would be able to push connect.
Old 05-20-2012, 11:25 AM   #4
AKA HVACTECHFW
try leaving the batteries out for 5 min.
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
djgrant (05-20-2012)
Old 05-20-2012, 12:05 PM   #5
Ok, good idea. Thanks.
Old 05-20-2012, 12:27 PM   #6
An old Tradesmen
Rewards Points: 7,278
How far a way, are you from the EIM.
Old 05-20-2012, 11:07 PM   #7
I don't have an EIM, so I assume you mean the t-stat. I've tried it from close range and far away. But usually I'm about 6 feet away.
Old 05-21-2012, 04:13 AM   #8
An old Tradesmen
Turn off the power to the furnace so the stat resets.
Old 05-26-2012, 10:11 PM   #9
I tried your suggestions but they didn't work and Plumbing Planet where I purchased it seems to think it's a bad remote. So they are sending me a new one.
The Following User Says Thank You to djgrant For This Useful Post:
hvactech126 (05-26-2012)
Carrier comfort zone II upgrade from comfort zone question detyianni HVAC 3 11-30-2010 01:27 PM
Dishwasher Control Panel Zen Nomad Appliances 0 10-02-2010 11:00 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Inifinity Control and Dual Fuel n2001nhl HVAC 1 10-03-2009 12:34 PM
carrier furnace and honeywell zone control issue bmccarron HVAC 14 09-20-2009 09:59 AM
