Honeywell MARD Dampers - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2014, 01:00 PM   #1
Rewards Points: 244
Question
Hi all,
I am hoping you can give me some input on how Honeywell MARD Damper works.
I understand that it is powered on opening and closing.
But, when it is at closed/opened position, does the motor keep running to keep it close/open, or once it reached the closed position, the motor turns off locking the damper on that state?
I installed a couple of them, and I notice that the motor keeps running when it reached maximum open position.
Thanks!
325_man is offline   Reply With Quote
Old 02-23-2014, 01:39 PM   #2
An old Tradesmen
Rewards Points: 7,414
It stays energized the entire time its open or closed.
Usually its used as a modulating bypass damper. Its a bit expensive as a bypass damper on an open or closed zone damper system.
Old 02-23-2014, 02:07 PM   #3
Rewards Points: 244
I notice the motor keeps spinning after it reached open/close state. Will it be burnt out if it stays like that for along time?
Old 02-23-2014, 02:17 PM   #4
An old Tradesmen
It shouldn't.
Old 02-23-2014, 02:27 PM   #5
Rewards Points: 244
OK, thanks!
I am worry because it feels warm after 1 hr of spinning.
Based on your explanation that it stays energized the entire time, it probably is normal to produce some heat and it probably has been designed to do so.
Old 02-23-2014, 02:56 PM   #6
An old Tradesmen
Yeah, at 100% modulation it would be opened and energized the entire time. So they are made to take the heat.
ARD vs MARD dampers BlueBSH HVAC 6 03-02-2011 07:36 PM
Honeywell TrueSteam wont work! Stewart Daniel General DIY Discussions 18 12-20-2010 07:41 AM
Manual dampers vs. motorized w/smart sensors and zone control... charljlee HVAC 0 06-27-2010 12:05 PM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
Replace Trane Weathertron (Baystat 339) with Honeywell RTH2410 ammiller2 HVAC 0 12-12-2009 09:50 PM
