Honeywell L8124L Settings On Oil Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 10-24-2010, 06:47 PM   #1
Honeywell L8124L Settings on Oil Boiler
My settings on the L8124L slant/fin oil boiler were set at Hi-170, Lo-150 and differential at 25, when would the circluator be running when there is a call for heat in the house?
Also, I have an Superstor Ultra indirect water tank connected as another zone for DHW, are the above settings correct for this type of DHW? Also, I have a wood boiler plumbed into this system, does the above settings seem correct for this as well?
shawnmd is offline   Reply With Quote
Old 10-24-2010, 07:11 PM   #2
An old Tradesmen
Rewards Points: 8,168
Those settings are fine. I'd use a slightly lower setting with an indirect though. Since you don't need it as high for an indirect. Probably 130 for low.
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 06:52 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
rusty restoration ; Peerless boiler and Honeywell 8124 controller, arthurheyman Plumbing 1 08-25-2010 05:42 PM
Honeywell Utica Boiler Valves Question cmariorussell HVAC 2 02-03-2009 09:54 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
