Honeywell IAQ Wiring Confirmation? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 02:11 PM   #1
Hi,
My first post, glad I stumbled across this great forum.
I'm replacing my current thermostat and humidistat with the VisonPro YTH9421C1010.
Current Equipment:
Carrier Furnace 58STA110
GeneralAire Bypass Drain Humidifier 1042LH
Current Setup
HUM1 goes the furnace board
HUM2 is splice in a blue cable that's run directly to the Humidistat control
HUM2 (Blue) -- Humidistat
COM (Orange) --> Humidistat
G (Green) --> G Thermostat
Com (Brown) --> C Thermostat
W (Black) -- W Thermostat
Y --> Not Used
R (Red) --> R Thermostat
See photo:
http://img717.imageshack.us/img717/4...rrentsetup.jpg
Planned IAQ Setup:
G (Green) --> G EMI
Com (Brown) --> C EMI
W (Black) -- W1 EMI
Y --> Not Used
R (Red) --> R EMI
Hum1 (Wire) --> C EMI
Hum2 (Wire) --> HUM2 EMI
Jumper Hum1 & RH together on the EMI
1 EMI --> 1 Thermostat
2 EMI --> 2 Thermostat
3 EMI --> 3 Thermostat
I guess the question I have is should I be removing the HUM1 cable from the furnace board? I do want the IAQ to control the humidstat and turn on the furnace blower when necessary.
kaddy is offline   Reply With Quote
Old 02-19-2012, 02:40 PM   #2
An old Tradesmen
Rewards Points: 7,328
Humidifiers com should go to the com of furnace. Jumper EIM R to HUM1 and then a wire from HUM2 to humidifier.
The Following User Says Thank You to beenthere For This Useful Post:
kaddy (02-19-2012)
Old 02-19-2012, 02:55 PM   #3
Thanks for the reply. I only have 2 wires coming from the humidifier.
So is this how it should look:
Humidifier wire 1 --> Furnace COM (on circuit board, this is the way it was originally)
Humidifier wire 2 --> HUM2 EMI
Jumper on EIM R to EIM HUM 1
Thanks!
Old 02-19-2012, 02:57 PM   #4
An old Tradesmen
yep, that it.
Old 02-19-2012, 04:38 PM   #5
Thanks,
Looks like most of it's working, but my humidifier isn't starting. I also don't see a way to adjust the humidity on the unit.
It show the humidity, also I can see it when I hit the more button, but can't adjust it.
Old 02-19-2012, 04:49 PM   #6
AKA HVACTECHFW
Rewards Points: 1,208
you must enable that function in the installer setup. 372 = 1 or 3 if you used an outdoor stat 374 = 2
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-19-2012, 07:27 PM   #7
Thanks, I have that set to 1, and I can control the humidity. I still can't seem to get the actual humidifier to kick in. I have it set to 60% max (currently at 33% in the house).
Anything look wrong with this?
Should I maybe remove HUM1 from the furnace board and wire it the C on the EMI, that's what the wiring guide has?
Old 02-19-2012, 07:31 PM   #8
I do have RH and Hum1 on the EMI jumped together, but that shouldn't matter as R, RC & RH all have a built in jumper.
I'm just using the unit thermostat for now, don't have the outdoor sensor setup yet.
Old 02-19-2012, 07:43 PM   #9
AKA HVACTECHFW
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
kaddy (02-19-2012)
Old 02-19-2012, 08:01 PM   #10
Rewards Points: 150
I installed this same t-stat last weekend and this is how I wired my humidifier - both leads from the humidifier connected to the EIM.
silversport is offline   Reply With Quote
Old 02-19-2012, 10:13 PM   #11
Thank everyone, it's all up and running now with both HUM 1&2 wired directly to the IEM.
I have a ventilation/exhaust switch wired above my thermostat. Anyone know how I would go about wiring this in the IEM for ventilation control, so I could program it to come on during the day for a short interval? It's currently controlled by a high voltage switch.
Honeywell thermostat wiring wcb22 HVAC 5 01-10-2011 05:54 AM
T-Stat Wiring - Lux TX9100e replaces Honeywell T8411R for Carrier Heat Pump/Cooling 99Problems HVAC 1 08-19-2010 01:44 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
