I have successfully installed my honeywell iaq THM5421C1008 thermostat.
I have a question about the humidity control. The humidity screen shows a 32% humidity reading on the upper left but the unit is apparently calling for 50% humidity located on the lower right. Why is it not able to get the humidity up to 50%? I have place the control on the setting of control of the fan is run by the need for humidity but the unit just dose not seem to turn on the humidifier enought. I have gone into test mode and the thermostat does turn on the humidifier. I have a recently installed desert spring drum humidifier that is supposed to do a house of 3000 square feet and my house id 2000 square feet. I gave it a few week to get the humidity level up. I have an outdoor temp sensor which is accurately working.
I set the thermostat to the mode where the fan runs when humidity is called for. That did not seem to be enough. What is the right humidifier for my application. This one uses far less water than other models.
Hoineywell has the Truesteam. But, the large unit, isn't really able to add that much moisture(12 gallons per day).
I prefer the EWC Autoflo steamer.
The small one is 16 gallons per day, and the large one is 22.
Hot water won't help the desert, it is a sump humidifier. So the water will cool down.
Flow through, is when fresh water is constantly flowing through it.
Is the outdoor temp sensor integrated with your humidifier? If it is it may be holding your humidity down, especially if your outdoor temp is low. Too much humidity and your windows will sweat. Around here if you have 50% humidity this time of year you won't see out of your windows.
Yes, The outdoor temp is integrated into the whole system.
This is correct. It wont raise the humidity to much inside if the outside temp is very low. It will steam the windows up. I have a zoned IAQ system with a truesteam setup.
Skuttle makes a good steam humidifier, but alot of maintenance comes with it, I use a Honeywell Flow-Through humidifier with a Invensys T-stat with Humidity sensing to turn the unit on and off, also have the outdoor sensor for the t-stat as well, and it works great.
Yeah, I looked up the charts that recommend what % humidity for the outdoor temps and my IAQ seemed to be tracking OK. I wonder why my thermostat has a 50% humidity in the lower right corner when it maintains 30 or 32% which matches the tables.
I don't know about yours but is this on the main screen more screen? Mine shows outside temp on the bottom right.
Well I'm sure it could be a setting option.
it is on the more pressed twice screen where it reports the humidity.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
