Honeywell HE120 Humidifier Humidistat Not Working Properly - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 09:15 PM   #1
Question
I just got finished installing a Honeywell HE120 whole house humidifier and it doesn't seem to be working properly. When I test the system in manual mode, the drum on the humidifier turns as it should. However when I set it to the highest setting, the drum stops turning.
My suspicion is that the humidistat is not far enough into the return air duct. It is mounted to the face of the return air duct as would normally be the case but my return duct is made of that 1" thick stiff insulation ducting. Is this the culprit of the humidistat not actuating the drum or is there something else. Do I need to figure out a way to mount the humidistat deeper into the return? Any recommendations on how to do that?
I haven't been testing the system for very long, does it take long for the humidistat to calibrate??
Any help is greatly appreciated....
jobondur is offline   Reply With Quote
Old 01-16-2013, 07:26 PM   #2
Bump.
Old 01-16-2013, 09:22 PM   #3
chitownken's Avatar
Rewards Points: 510
What is the current humidity level in the house? Might be over the maximum setting on the humidistat.
chitownken is offline   Reply With Quote
Wiring Aprilaire humidifier to Honeywell thermostat MurphyMan HVAC 6 01-04-2013 03:52 PM
Lennox WP18 Humidifier w/ Pro1 IAQ Humidistat species8472 HVAC 0 12-27-2012 12:03 PM
Honeywell HE260A Humidifier install rdtour HVAC 3 02-02-2011 10:10 AM
AprilAire 550 Humidifier not working? mcvane HVAC 2 11-22-2008 12:15 PM
sump pump working properly? Karen from Iowa Plumbing 7 06-18-2008 08:08 AM
