Honeywell Furnace Will Not Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 03:40 PM   #1
Honeywell furnace will not heat
I have replaced the ST9120C circuit board with St9120B,U. Ignitor still does not come on. Green led blinks every second without pause. This furnace has the SV9500M gas control valve. Furnace is 23 years old. I know it is not the thermostat. The xfmr puts out 27VAC. I checked the voltage going to the ignitor pins(two blue wires) & ground, measure 27volts on one and zero on the other.
red4re is offline   Reply With Quote
Old 11-07-2011, 05:08 PM   #2
An old Tradesmen
Rewards Points: 6,464
You don't have a Honeywell furnace, they don't make furnaces.
probably a bad HSI.
Old 11-08-2011, 01:30 PM   #3
OK, the parts that are made by Honeywell are the circuit board, ST9120 and the gas valve ignition control SV9500. Is HSI the smartvalve system control (SV9500)?
Old 11-08-2011, 01:34 PM   #4
raylo32's Avatar
Rewards Points: 1,238
HSI= hot surface ignitor
raylo32 is offline   Reply With Quote
Old 11-08-2011, 01:56 PM   #5
The HSI is part of the smart valve control, right. That means that the SV9500 will need to be replaced?
Old 11-08-2011, 07:31 PM   #6
An old Tradesmen
The HSI is controlled by the Smart Valve.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 03:21 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 09:56 AM
Wiring a RobertShaw 9870i to Gas Furnace & Heat Pump jerfer HVAC 11 12-21-2008 10:09 PM
