Honeywell Furnace/ac Blower Runs Continuously Not Heat Or Ac - HVAC - DIY Chatroom Home Improvement Forum
Old 05-29-2010, 06:21 PM   #1
honeywell furnace/ac blower runs continuously not heat or ac
I have a honeywell furnace/ central air unit. Does not look to be that old. The heat worked fine during winter months. Weather warmed up and furnace shut off. Once it got cold a few nights the heater would not start and blower fan runs continuously. It is now summer and the A/C unit will not start either which did work fine. I can not find a fuse and have changed thermostat as well as reset breaker. Any help troublrshooting would be a great help as I do not have the money to hire an HVAC specialist. Thanks in advance, Matt
grnded is offline   Reply With Quote
Old 05-30-2010, 05:18 AM   #2
An old Tradesmen
Rewards Points: 7,370
Does the fan run all the time? How dirty is your air filter?
blower runs, with no heat captjack HVAC 6 12-14-2010 02:15 PM
Goodman Heat Pump - Blower Motor FireFighter254 HVAC 9 03-05-2010 06:18 AM
Bizarre Heat Pump and Blower Behavior gatorinsc HVAC 3 01-11-2010 03:32 PM
Blower fan runs continuously mgeller HVAC 5 04-19-2007 09:27 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
