Old 10-24-2011, 06:25 PM   #1
Honeywell Focus PRO6000 Th6220D1002
So this is a new Tstat which was recommended by the supplier to go along with our new furnace. My worry is that it is to sensitive. I notice this morning that it cycled 3 times in less than 45min. It was set to 70* which the furnace turns off at but when it came back on it still read that the Temp was 70* and the Call for heat temp was 70*. Are there settings i am unaware of? I dont see anything in the manuals.
MNice is offline   Reply With Quote
Old 10-24-2011, 07:01 PM   #2
What you don't see is the decimal point. On at 70.1 off at 70.9
That's the honeywell way.
Master of Cold is offline   Reply With Quote
The Following 2 Users Say Thank You to Master of Cold For This Useful Post:
gregzoll (10-24-2011), MNice (10-24-2011)
Old 10-24-2011, 07:16 PM   #3
Really! Doesnt this make a furnace short cycle more?
Old 10-24-2011, 07:21 PM   #4
An old Tradesmen
Check to see what then CPH is set to. It could be set to for, if it is, set it to 3, or 2.
Old 10-24-2011, 08:56 PM   #5
Setup function #5(Stage 1 heat cycle rate(CPH:Cycles/hour) is set to 3 (for hot water systems & furnaces of over 90% Effiency
#5 also has a * that states (Other cycle rate options: 2,4,6,7,8,10,11, or 12 CPH)
Setup function #6(stage 2 heat cycle) is set to 5(for gas or oil furnaces of less than 90% efficiency.
Shouldn't my 2nd stage be set for of 90% efficiency? It is a 95% Comfort-Aire.
Old 10-24-2011, 09:32 PM   #6
An old Tradesmen
Setting 6 to 3 will tend to give you more short cycling. Set 5 to 2.
Your furnace is probably over sized.
Old 10-27-2011, 10:57 PM   #7
It's a 75K btu. 1st stage is 45k and 2nd is 75k. it hasn't been remotely cold enough to call for second stage. It is what they spec'd for our house. Could it be a supply/return pressure problem? There is no faults being thrown. Our night time temp setting is 63*. It calls for it to be 68* @ 5:30am. Between 5:30 and 6:30 it will cycle 2-3 times. I am just wondering if there is a parameter not being met and it calls for it to shutdown. It does shutdown normally i.e. burners turn off, fan continues to run for "x" amount of time, and the exhaust purges 'x" amount of time once burners turn off.
Noticed doin the Tstat test in the manual when the furnace calls for heat it seems to be in the 2nd stage and not utilizing the 1st stage.
Old 10-28-2011, 05:19 AM   #8
An old Tradesmen
Are you sure the wires for second stage are connected at the furnace.
Old 10-28-2011, 08:23 AM   #9
This is how it is wired.
Need Some Start up help.
Old 10-28-2011, 02:37 PM   #10
An old Tradesmen
It looks to be wired right.
Old 10-28-2011, 03:04 PM   #11
Thats why i wondered if it might be a factory setting on the furnace end.
Old 10-28-2011, 03:10 PM   #12
An old Tradesmen
Could be the dip switches aren't set right, they have to be set to use the thermostat.
The Following User Says Thank You to beenthere For This Useful Post:
MNice (10-28-2011)
Honeywell Focus PRO6000 namasil HVAC 7 10-02-2011 06:09 AM
Honeywell TrueSteam wont work! Stewart Daniel General Discussion 18 12-20-2010 08:41 AM
Honeywell Focus Pro 5000 gobob2 HVAC 2 01-27-2010 08:49 PM
Replace Trane Weathertron (Baystat 339) with Honeywell RTH2410 ammiller2 HVAC 0 12-12-2009 10:50 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 09:33 AM
