Honeywell ERV ER200B - HVAC - DIY Chatroom Home Improvement Forum
Old 11-23-2009, 07:36 PM   #1
I am using American Aldes ZRT registers which will permit a constant low flow ventilation in my bathrooms until a timer is activated. At that point a damper on the ZRT opens, a microswitch engages to trigger the Honeywell ERV to high speed mode. The ERV schematic shows +12 Red being switched to the Black dehumidifier line to trigger the ERV to high speed to high speed. When I open the trigger line jumper, the ERV continues to run on high speed. What is not covered in the technical documentation is if an internal ERV timer is activated.
I've contacted the manufacturers & await their response. I am wondering if anyone on the forum knows?
Backhertz@yahoo is offline   Reply With Quote
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 08:33 AM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
