Old 01-14-2006, 08:18 AM   #1
Honeywell Electric Thermostat Model T498
Recently a technician replaced two electric baseboard heating units in my apartment. Unfortunately, he/she was unable to reconnect the thermostat to the units. The thermostat now works like a light switch, on/off. The one baseboard unit makes a loud humming noise and once turned on, within 20-30 minutes the temperature is between 70-80 degrees fahrenheit:confused:
Any assistance would be greatly appreciated as weather predictions are for cold and snowy weather within the next 24-48 hours.
Thanks.
staylori is offline   Reply With Quote
Old 01-14-2006, 01:25 PM   #2
Looks like you might be on line so I'll take a stab at it.<P>
I believe your baseboard electric is required to be on a working thermostat. If you are not the owner of your apartment I would demand that the situation gets fixed pronto. If you are the owner I would call and electrician soon. At the very least they have controls that mount on the baseboard. Hopefully someone will be along here soon and can confirm that a stat is required. HS.
K2eoj is offline   Reply With Quote
Honeywell Thermostat code 0340-reset? George Foote HVAC 3 02-14-2011 01:52 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
honeywell chromotherm thermostat - help? mkbgriffen HVAC 4 12-26-2006 01:46 PM
noma electronic thermostat model thm303m rickevin29 HVAC 7 10-22-2006 11:29 PM
