Honeywell DIY Or Professional Thermostat? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-10-2009, 12:06 AM   #1
Honeywell DIY or Professional thermostat?
I need to replace my old thermostat, and am debating between the Honeywell "DIY" model RTH7600D or the "Professional Installer" model VisionPro 1H/1C. My question is, what is so special about the VisionPro that it requires a professional installer? If I go with the RTH7600D am I missing out on some great feature? I couldn't notice any real feature differences. Honeywell's website makes a very clear distinction between DIY and Professionally installed, so I'm leary about buying the VisionPro.
Not sure it matters, but here is the background of my problem:
I currently have a Honeywell Chonotherm III, model T8601C1047. I have a
heat pump system (I think it is a simple 1 stage heat pump). After the
AC system shuts off, the fan keeps running (for hours sometimes). I'm
guessing it may be the thermostat. Do you think this is likely? I would like the easiest replacement thermostat, so that I can re-hook up the wires the same way they are now:
O -> white
W -> yellow, plus a red2 wire that connects to Y
G -> green
C -> blue
R -> red
Rc (not connected)
B (not connected)
Y -> red2 wire to W
Thanks,
Mark
beiley is offline   Reply With Quote
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Honeywell VisionPro Thermostat infoskr HVAC 32 12-17-2008 04:44 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 02:30 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
