Honeywell Chromotherm Thermostat - Help? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-24-2006, 05:34 PM   #1
honeywell chromotherm thermostat - help?
I am trying to replace the battery in the honeywell chromotherm III thermostat. I have loosened the screws at the bottom, but cannot figure out how to remove the unit from the wall. Does it lift up or out? Is there anything else that I need to loosen before I can do it. I have tugged, but it isn't coming off easily.
mkbgriffen is offline   Reply With Quote
Old 12-25-2006, 12:29 AM   #2
Pull it towards you and lift up.
acefurnacefixer is offline   Reply With Quote
Old 12-25-2006, 05:31 PM   #3
you should find a screw on both sides buttom then pull out bottom slowly and lit up. good luck
trollmastergeneral is offline   Reply With Quote
Old 12-26-2006, 08:21 AM   #4
Is there an ECHO in here?
Old 12-26-2006, 12:46 PM   #5
mkbgriffen,
Here are copies of the owner's manual for your Chronotherm III:
http://www.honeywell.com.au/business/acs/acp/ecc/manuals/T8602_&_T8611_(Chron.pdf
http://www.gogeisel.com/geiselonline...well/T8621.pdf
...Christopher
Christopher is offline   Reply With Quote
Honeywell Thermostat code 0340-reset? George Foote HVAC 3 02-14-2011 12:52 PM
Carrier Infinity Control VS Honeywell VisionPRO 8000 Theromostat super_man4471 HVAC 2 04-26-2007 02:27 PM
Lux 722E Thermostat mgkicker HVAC 3 10-27-2006 01:40 PM
Honeywell Electric Thermostat Model T498 staylori HVAC 1 01-14-2006 12:25 PM
