-   -   honeywell chromotherm thermostat - help? (http://www.diychatroom.com/f17/honeywell-chromotherm-thermostat-help-5545/)
mkbgriffen 12-24-2006 05:34 PM
I am trying to replace the battery in the honeywell chromotherm III thermostat. I have loosened the screws at the bottom, but cannot figure out how to remove the unit from the wall. Does it lift up or out? Is there anything else that I need to loosen before I can do it. I have tugged, but it isn't coming off easily.
acefurnacefixer 12-25-2006 12:29 AM
Pull it towards you and lift up.
trollmastergeneral 12-25-2006 05:31 PM
you should find a screw on both sides buttom then pull out bottom slowly and lit up. good luck:thumbsup:
acefurnacefixer 12-26-2006 08:21 AM
Is there an ECHO in here?
Christopher 12-26-2006 12:46 PM
mkbgriffen,
Here are copies of the owner's manual for your Chronotherm III:
http://www.honeywell.com.au/business/acs/acp/ecc/manuals/T8602_&_T8611_(Chron.pdf
http://www.gogeisel.com/geiselonline...well/T8621.pdf
...Christopher
