Old 01-08-2013, 10:19 PM   #1
Honeywell 8001C replacement
Our thermostat is on the fritz and needs to be replaced. It shows the incorrect room temperature and is cycling the furnace at the wrong times.
This model seems to be no longer made but I was hoping I could find a compatible one where I could just snap the top into the existing baseplate. Has anyone done this or is that too much to hope for? (The 5-2 programming is sufficient).
I couldn't figure this out from the Honeywell website. Also, the new thermostats seem to require batteries whereas the 8001C did not
unmesh59 is offline   Reply With Quote
Old 01-09-2013, 08:18 PM   #2
hi mfgs like to change things on us alot ,, so you may have to go with new style as they prob wont make a direct snap on replacement . batteries only keep the program in case of power failure ,,
hvac dude is offline   Reply With Quote
Old 01-09-2013, 08:20 PM   #3
Looks like I should start examining the wiring of the thermostat in anticipation of having to rewire to a new one
Old 01-09-2013, 08:22 PM   #4
if is just a straight foward heat/cool system they make them very user frendily to replace
Old 01-09-2013, 08:30 PM   #5
That is encouraging. I believe it is a straightforward single stage heat/cool system.
Thanks.
Old 01-09-2013, 08:34 PM   #6
yw my pleasure ,keep in touch if you got any questions or problems . id say stay with honeywell its a good product
Honeywell / Honeywell thermostat replacement question. FatBear HVAC 12 10-24-2012 01:41 AM
Honeywell TrueSteam wont work! Stewart Daniel General Discussion 18 12-20-2010 08:41 AM
Honeywell Thermostat replacement khanma1 HVAC 2 08-01-2010 01:35 PM
Honeywell R8182A Replacement jregal HVAC 1 01-14-2010 09:17 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
