#1 |
honeywell 7400
connecting a honeywell 7400 to a rheem rbhb-25j21suea heatpump
old stat yellow-y blue-b red-r labeled x(looks pink could be brown)-x green-g white-w2 w2 jumped to e |
#2 |
honeywell 7400
What was the old tstat?
#3 |
honeywell 7400
old stat honeywell with mercury
it says heat pump themostat i can't find a number on it |
#4 |
honeywell 7400
What type of heating and cooling are we dealing with here: furnace, A/C only, Heat Pump, boiler, etc?
#6 | |
honeywell 7400Quote:
color old new yellow y Y red r R/RC (jumpered) green g G white w2 Aux/E (jumpered) The other two wires b and x I cannot be sure of without knowing the old tstat model. My guess is one is the common/neutral (wire to C) and the other for your reversing valve (wire to O/B). Under these circumstances I recommend a staged approach to wiring up. First get power to the tstat with R and common/neutral (try blue/b), and test. Next wire up G and test your fan is working. Next get your Aux heat to work. Finally wire up the reversing valve and test both heat and cool. You also need to configure the RTH7400, so read the manual carefully. |
| Display Modes | |
| new honeywell rth6300b to replace very old honeywell thermostat | Designman20 | HVAC | 2 | 05-06-2009 05:43 AM |
| Wiring/Programming of a Honeywell TH8320 Thermostat | homrjheath | HVAC | 4 | 10-15-2008 02:30 PM |
| Wiring help - Honeywell Thermostat w/ Carrier Heat Pump | Tom Williams | HVAC | 7 | 09-14-2008 08:40 AM |
| Changing from one Honeywell to another... | LeroyFrick | HVAC | 1 | 11-03-2007 12:33 PM |
