Honeywel Gas Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 05-21-2013, 10:39 AM   #1
Honeywel Gas Valve
My furnace won't ignite. When I push the grey button for the pilot and release it, the pilot goes out and the furnace won't ignite.Is there some check or adjustment I can do to make the gas valve operate.
Petdwd is offline   Reply With Quote
Old 05-21-2013, 11:29 AM   #2
REP
Sounds like you need a new thermocouple.Suggest you buy only a Honeywell or Penn thermocouple,the off brands are junk.
REP is offline   Reply With Quote
Old 05-21-2013, 12:14 PM   #3
how
Rewards Points: 1,102
Make sure that when the pilot is lit that you keep the grey button pushed down continuously for a minute before releasing it.
The thermocouple should be enveloped by the pilot flame. If not, then your furnace probably needs to be serviced.
how is online now   Reply With Quote
Old 05-21-2013, 02:33 PM   #4
FClef's Avatar
Rewards Points: 160
If the pilot flame is yellow and looks lazy and not a strong mostly blue flame then you may need to clean the pilot assembly. It also could be the thermocouple is bad. The thermocouple is something you can replace fairly easily however I do not recommend that you try to service the pilot assembly yourself. Call a professional.
FClef is offline   Reply With Quote
Old 05-21-2013, 06:39 PM   #5
Rewards Points: 582
clean pilot assy ,and orifice change thermocupler ..be good to go ben sr
Shut off valve for outdoor spigot C4per Plumbing 15 11-24-2012 08:50 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 04:04 AM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 01:02 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
