Home Hvac - HVAC - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 07:56 PM   #1
Home hvac
Hello, replaced outside fan motor 3wks ago. System worked great until fri. night. They keep the thermostat at 73. So it was good. Then outside fan quit,unless i manually closed contact,then ut would run but not full speed. Also fan motor seemed to be very hot!! Thanks for any help,its only 103 outside!!! Yes Texas!
TonyM. is offline   Reply With Quote
Old 07-29-2012, 08:12 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Try the hvac section down below for a slew of answers and folk that'll help, but did you change the run capacitor?
I'm an hvac tech in Houston, btw.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
TonyM. (07-29-2012)
Old 07-29-2012, 08:26 PM   #3
Tried testing cap. But not getting any readings. its a three prong,tested w/ meter on resistance. My meter is digital shouldnt i have it on ohms? Another site said on Voltage??? But reading was just a 1 between all 3. Thanks for any help.
Old 07-31-2012, 05:18 AM   #4
An old Tradesmen
Rewards Points: 6,130
Moved to HVAC forum.
Old 07-31-2012, 05:20 AM   #5
An old Tradesmen
Capacitors are tested by reading micrfarads.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (07-31-2012)
Old 07-31-2012, 06:22 PM   #6
Rewards Points: 1,214
Did you replace the capacitor at the same time you replaced the motor as asked in #2?
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Old 08-01-2012, 05:41 AM   #7
No,cap was not replaced at same time as fan motor. Cap tested good. But this time cap was bad,and replaced. All is good! Thanks to all who helped. But should cap have been replaced same time as fan motor? All info is appreciated. Thanks again. Great app.Tony.
Old 08-01-2012, 05:43 AM   #8
An old Tradesmen
Anytime you replace a motor, the cap should be replaced.
HELP!!! How much owe my HVAC repairman? Is he competant? MB1 HVAC 23 02-01-2012 03:42 PM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
New HVAC system in my home saby HVAC 2 01-14-2011 07:31 PM
History of Lomonaco's Iron Concepts & Home Decor John Lomonaco Introductions 0 11-08-2009 11:39 AM
