Home Furnace In Garage... - HVAC - DIY Chatroom Home Improvement Forum
Old 01-08-2009, 09:52 AM   #1
Home furnace in garage...
Hooked up my newly purchased used house furnace in the garage. I have a problem though. I hooked up the t stat (I have the W & R wires hooked up to the t stat) and I can get the fan to turn on but the ignition process does not initiate. Usually the direct vent motor would start up followed by the igniter... but nothing. Any ideas on what I should check first. I did notice there were two sets of R & W terminals that have what look like tstat wires. Here is a pic. I am connected to the right set
lfreng is offline   Reply With Quote
Old 01-08-2009, 10:06 PM   #2
JohnH1's Avatar
It's not real clear but from what I can see you need to use the lower right Red and the upper right white.
Do not tie across the transformer power leads R & C this can blow the transformer or thermostat or both.
Good luck.
Additional note: If this is setting on the floor in a garage be carefull gasoline fumes can beignited by the exposed flames. You should use a sealed combustion unit in a garage or if not sealed combustion it needs to be 8FT off the floor if I rember corectly.
JohnH1 is offline   Reply With Quote
Coleman Mobile Home Gas Furnace Problems Cberkimer HVAC 13 11-16-2014 07:51 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 09:34 AM
miller mobile home furnace wont keep running jb9270 HVAC 4 01-30-2007 10:12 AM
