Home Central Air Unit Has No Freon Recharge Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 04-28-2009, 07:30 PM   #1
Home Central Air Unit has No Freon Recharge Valve
My home central air unit was not producing any cold air, so I called someone in to look at it. The unit is an Armstrong 38HWC182A. The technician said it had a low freon level. He also said the unit had no recharge valve, and that he would have to install one in order to recharge it.
Is this normal? That is, an A/C unit with no recharge valve.
nofrey is offline   Reply With Quote
Old 04-28-2009, 08:40 PM   #2
An old Tradesmen
Rewards Points: 6,516
The unit you have is considered a small appliance. And the manufacturer is not required to install access valves/fittings when they make it.
And they don't.
So that tech was correct.
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 06:13 AM
Used Central Air Unit? shep28 HVAC 2 04-21-2007 08:59 PM
