Home Air Conditioner Compressor Starts The Stops When Fan Comes On - HVAC - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 08:11 PM   #1
home air conditioner compressor starts the stops when fan comes on
My home air conditioner compressor starts then stops when fan is manually turned on. The fan dos not come om when on auto. I have replaced the fan capacitor with no change. Any ideas?
vpnolan is offline   Reply With Quote
Old 07-06-2012, 09:23 PM   #2
Sounds like the thermostat isn't wired right.
Old 07-06-2012, 09:51 PM   #3
I had a similar problem with a relative's Rheem. Hooked up new Hunter 44272 tstat as "Single Stage Heat Pump w/ Aux Heat" = wrong. Works correctly as "Single Stage Heat Pump w/ Heat Reversing" For me, it was "B" and "O" wires.
dougand3 is offline   Reply With Quote
Old 07-07-2012, 12:26 PM   #4
Thanks. However the tstat is workiing and the compressor kicks on. The hot and cold lines act as normal. The fan does not click on automatically with comopressor. When I kick on the fan manually, the compressor shuts down. Have replaced the run capacitor for the fan but that was not the issue.
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
History of Lomonaco's Iron Concepts & Home Decor John Lomonaco Introductions 0 11-08-2009 10:39 AM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 09:34 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
