Hole In Return Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 02-24-2009, 09:19 AM   #1
Hole in return duct
I found this hole in a joist bay that is being used for a return vent (unfinished basement area above furnace). My guess is they were originally going to run the gas pipe thru this hole.. but ended up enclosing it for the return vent. They subsequently suspended the gas line below to the left. I feel this hole should have been covered up in some way so that it does not degrade the return vent from pulling air via the living areas upstairs. Am I correct in this line of thought? If so, what would be the proper way to cover this hole?
DIY_JC is offline   Reply With Quote
Old 02-24-2009, 09:42 AM   #2
Chicago, IL
Michael Thomas's Avatar
Probably got busted under 404.1 (not in or through a circulating air duct) and had to relocate the line.
Michael Thomas is offline   Reply With Quote
Old 02-24-2009, 09:59 AM   #3
Rewards Points: 502
The size of whole wont affect the return system. I'd cover it up with a piece of sheet metal, if that isn't handy then you could nail a piece of plywood over it.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 02-24-2009, 11:44 AM   #4
They did the right thing by removing what was running through there, but now you need to cover that hole. It may not be affecting you much, but then there is that idiom about death by 1000 cuts.
dac122 is offline   Reply With Quote
Old 02-24-2009, 02:34 PM   #5
it'll suck dust that Will eventually pervade the whole area.
Piece of foil tape or expanding foam insulation will do the trick
hvaclover is offline   Reply With Quote
Old 02-24-2009, 04:42 PM   #6
An old Tradesmen
Rewards Points: 6,086
A strip of lath.
Old 02-24-2009, 04:52 PM   #7
They still make that? Thought it went the way of wet plaster?
Old 02-24-2009, 05:28 PM   #8
An old Tradesmen
Plenty of furring lath around.
Old 02-24-2009, 05:33 PM   #9
Firring I know, lath I always associated with cool old homes from the 1920 and 1930 era.
Just a regional thing I guess.
Old 02-24-2009, 07:14 PM   #10
An old Tradesmen
Your thinking of plaster and lath.
Its still around too. Just not as common.
Old 02-24-2009, 09:51 PM   #11
Rewards Points: 150
Looks Like a 1893 silver dollar and a little epoxy should do it!
Gary
Gary_602z is offline   Reply With Quote
Old 02-24-2009, 11:24 PM   #12
A birdie would fill that hole nicely.
or a scrap piece of plywood, or a blank 4x4 cover.
chard is offline   Reply With Quote
Old 02-25-2009, 06:35 AM   #13
If you happen to have a matching hole saw you can cut your own plug and drive it in. A scrap of foam board works nicely for this.
Chemist1961 is offline   Reply With Quote
Old 02-25-2009, 10:37 AM   #14
All this advice just to cover a friggin' hole/
You guys got to much time on your hands.
question on return duct familyman HVAC 13 01-25-2009 12:05 PM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 10:38 AM
Hole in my dryer duct... QuattroStylez Building & Construction 6 11-30-2008 05:11 PM
Water in (and around) return duct kennelm HVAC 6 06-18-2008 07:13 AM
