Hole In HVAC Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 04:04 PM   #1
Hole in HVAC duct
Recently I had some water stains begin to show in my ceiling downstairs in my living room. I had a plumber come in and he cut some of the ceiling out and discovered a hole in the duct work. You can stick your fnger in it and it is completely soaked. Is this normal to have that much condensation I the duct? Also could it really cause that much water stain? Also all the drain lines were checked and not leaking.
Hole in HVAC duct-image-2180879153.jpg   Hole in HVAC duct-image-1479038405.jpg
Dooggins1 is offline   Reply With Quote
Old 07-09-2012, 08:39 PM   #2
JJboy's Avatar
http://www.findtape.com/product580/J...id=2&info=hvac
Just use this tape to fix the hole.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-09-2012, 09:52 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Mice will eat through anything these days.
Old 07-10-2012, 05:22 AM   #4
You shouldn't have water/moisture in your ducts. If you do, then you've either got a clogged drain, a dirty evap, faulty install, etc etc. I'd suggest calling your HVAC tech out to take a look. It'll just do it again if you don't fix the source.
scottmcd9999 is offline   Reply With Quote
Old 07-10-2012, 05:28 AM   #5
But should there really be that much condensation in the duct?
Old 07-10-2012, 05:30 AM   #6
See my last post - there should be no water inside your ducts, or in the insulation of your ducts.
Old 07-11-2012, 09:28 AM   #7
No clogged drain and the pan under the evaporator is dry. See anything abnormal in the pics?
Hole in HVAC duct-image-3630978269.jpg   Hole in HVAC duct-image-2280737737.jpg
Old 07-11-2012, 01:55 PM   #8
Rewards Points: 610
shut off AC until house warms up, disconnect condensate drain or be able to observe condensate pan then, run the AC full tilt to see if the condensate is actually going to drain..the supply fan air pressure could be too close to the coil or too high causing the condensate to carry over into the ductwork.thereby accumulating and rusting a hole through etc., just a thought - seeing as the drains aren't plugged --rusty ductwork just past the coil could also be an indicator AND yes..there is a ton of condensate during cooling ..that's how it reduces the Relative Humidity- it lowers the dew point at the coil causing it to rain cats and dogs!
techpappy is offline   Reply With Quote
Old 07-11-2012, 03:10 PM   #9
The Owens Corning page for HVAC professionals has a lot of great resources and information to help with problems like this one. Whether it's information on products or info on continuing education, the OC page is an incredibly helpful resource to use for all types of situations. Check out the page here: Hope this helps and good luck!
alexbest27 is offline   Reply With Quote
Old 07-11-2012, 07:21 PM   #10
Visit it where?
Old 07-12-2012, 07:31 AM   #11
Rewards Points: 610
TO: Doggins1
Just click on the blue HVAC. It will take you to the OC site which is nothing more than a big ad for insulation products.
SO anyway..Have you tried any of the suggestions to find out where the water is coming from. Would be interested to know. Hope you find the solution.
Tech Pappy
Old 07-12-2012, 09:13 AM   #12
Rewards Points: 156
I'm surprised nobody mentioned it, but there may not be a condensate draining issue at all. If the ductwork is going through unconditioned space, the issue could simply be that due to the hole, the condensation is forming where the hole is at. With the damp air here in the southeast USA, I could very well see where the cool conditioned air is blowing into the warm, humid air in the attic and causing condensation to form in the duct where the hole is, and on any subsequent materials around the hole in the unconditioned attic...IE the hole in the duct is acting like a cold drink sitting on the patio table during the summer dripping moisture. I would first simply work on sealing up the hole and any other leaks, and then sealing it all up good with a good layer of insulation.
av-geek is offline   Reply With Quote
cut out a 6x10 hole, but need to use 4 inch duct Tonglebeak HVAC 17 06-21-2012 09:17 PM
Replacing Duct Tape Used on HVAC Ducts yarrick19 HVAC 5 06-17-2012 11:29 PM
Hole in the air duct edta1 Building & Construction 1 07-06-2011 12:08 PM
hvac duct through fire wall acerunner HVAC 12 07-06-2010 08:44 PM
Hole in return duct DIY_JC HVAC 13 02-25-2009 09:37 AM
