Hit Seized Compressor With 2x4 When And Where? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-18-2014, 03:28 AM   #1
Rewards Points: 452
hit seized compressor with 2x4 when and where?
How much impact can the compressor shell withstand?
If you hit it hard enough to mangle the metal, can it explode and send shrapnel flying?
Do you hit it while the cooling is turned on, or when the system is off?
and where do you hit it?
Is the top rounded edge ok, shown with arrow below....
btw, my compressor is a Bristol
pman6 is offline   Reply With Quote
Old 07-18-2014, 04:30 AM   #2
An old Tradesmen
Rewards Points: 6,928
Generally hit it while its trying to start. I use a rubber mallet.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (07-19-2014)
Old 07-18-2014, 07:31 AM   #3
HVAC TECH.
KKinnaman's Avatar
I concur with beenthere about the rubber mallet, but I always try a hard start kit first.
KKinnaman is offline   Reply With Quote
Old 07-19-2014, 05:44 AM   #4
Rewards Points: 1,216
Be prepared to buy a new compressor or Condensing unit. Once they stick I guarantee you they will stick again. So even if you free it it's temporary.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 07-19-2014, 06:06 PM   #5
Rewards Points: 484
From what I hear about Bristol, better off hitting it with a truck.
sammy37 is offline   Reply With Quote
Old 07-22-2014, 05:23 PM   #6
Rewards Points: 1,910
I never heard of this before. So how long does a typical unit run after it's been "unseized" with a mallet? Is this just to get you by for a few days in hot weather before a replacement can be installed or is it a longer term fix?
BTW, those fins look pretty plugged up, would that cause overheating of compressor that could lead to seizing?
Old 07-22-2014, 05:38 PM   #7
An old Tradesmen
How long it last, varies by the unit.
Over heating can thin the oil and cause it to seize. So can lack of oil return.
Old 07-22-2014, 06:26 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 1,858
Not likely it will last long. Hard start kit usually gets you 1 more year of life in my experience. Bristol I would not even waste a hard start kit on.
You also may end up with a burnt out compressor and acid in the system. If you want to re-use the Freon lines then you got one he*ll of a mess and expense to clean up. I would replace that unit B4 all that happens ( now ).
