Is A Higher Voltage Capacitor An Advantage? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 08:02 PM   #1
Is a higher voltage capacitor an advantage?
The 3.5 year old capacitor, 370v, 45/5𝜇F, on my Amana air conditioner is bad. One with the same capacitance rated for 440 volts is available for a bit more money. Is a cap rated for higher voltage likely to last longer? Thanks.
flanso is offline   Reply With Quote
Old 09-15-2012, 08:13 PM   #2
JJboy's Avatar
No, Just get American brand....no the $hit china ones
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-15-2012, 08:23 PM   #3
I have been unable to find one made in the US. Do you know of a source?
Old 09-15-2012, 08:36 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Whereabouts in Houston are you? I-10 @ Beltway (westside) myself. Go to any old Grainger and get whatever they have.
Or order online. http://fierychill.com/components/ele...rs/made-in-usa
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-15-2012, 09:01 PM   #5
An old Tradesmen
Rewards Points: 6,448
A 440 volt one(used on a motor that calls for a 370 volt) will tend to run a little cooler then a 370 volt one.
Old 09-16-2012, 12:20 PM   #6
Doc, I'm in the Montrose area near Waugh and W. Gray. The on-line Grainger catalog shows both the 370 and 440 volt caps are from China. Have you found the Grainger caps to be reliable? The US made caps from fierychill look very good except for the 4 day transit time or the additional cost of expedited delivery. Johnson Supply is near me on Studemont though I'm not sure they'll sell to me since I'm retired and no longer in the business. Do you know of Johnson?
Old 09-16-2012, 01:23 PM   #7
Let me go check my truck and see if I have one. I have to come that way in a bit.
I'm not too picky as to where they're made, could really care less. I've never had one just die on me brand new. And we're not talking monetary amounts that'll break you either.
No, I don't use Grainger as I'm an actual hvac technician, everything I get comes from the actual dealer supply houses. Grainger simply sells to the public, dealer supply houses won't.
Let me go check.
Thanks.
Old 09-16-2012, 01:52 PM   #8
Hello?
Thanks.
Old 09-16-2012, 01:57 PM   #9
Johnson will not sell to you, no. I know all the Johnson locations and other various supply houses in Houston as well. None will sell to the public, none of the major retailers that is.
Grainger you can simply walk into to.
Thanks.
Old 09-16-2012, 04:05 PM   #10
Doc, If you have one, I would be happy to buy from you.
Old 09-17-2012, 06:29 PM   #11
Grainger had a 440 volt unit that I installed and everything works fine. Thanks everyone.
Reduced Voltage Supply to Outdoor Light mark2741 Electrical 6 09-05-2010 03:44 PM
high voltage fire alarm jungboklee Electrical 3 01-26-2009 10:07 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 10:01 PM
